Technical Fiat 500 1.2 Lounge alternator
thank you, the AA guys said the battery was fine and told me it was the alternator which is why I brought this up. If the alternator is dead ( because the voltage did not rise above 12 when the engine was started, will this have an effect on the new battery?
He appears to need training!
I tested the battery and it had 2.6 volts. Charged and started with jump leads and was 11.6 volts but dropping steadily with nothing on.
I just wanted to add my tuppence worth regarding the above. As we all know, any less that 12.2V is potentially a flat battery, so if it's reading 2.6V its seriously discharged. if you connect it to a fully charged battery, the charge from the good battery will flow into the bad battery with a potential around ~10V limited only by the internal resistance of the bad battery. Apart from the possiblity of making the jump leads glow like an electric lamp (if they're the cheap ones), will flatten the good battery very quickly.
Just saying....
I've bought a new battery - it is going to be delivered as work has played a major factor in my ability to go to any motor factor place in Swansea even though there quite a few.
Did you get your new alternator?
Yes, the 120a one. When you cross referenced the part number, it was coming out at a much greater price. So the battery and alternator cost £180. I wonder how much the local garage (0.5 miles) might charge to fit the alternator(they are far more expensive than the garage I use on the other end of Swansea).
By now you know how difficult it is to do, but armed with that knowledge, why don't you do it yourself?
A lounge should have aircon, so the alternator is below the pump. A little awkward to get at, and has to be removed downwards, past the drive shaft. Fiat recommend moving the drive shaft, by releasing the bottom ball joint. So a bit of grovelling underneath, with the car on stands.
Dear me, just called local garage in village and they quoted me 3 hours at £90 per hour labour to fit alternator.
As you say, Oh deary me! So far I've never had to do one on a 169, although the old Mk1 Panda had to have one, but it didn't have air con and was easy. I do believe you have to remove the driveshaft because it can't come out the top, but I think once the bottom ball joint is released the whole hub can be moved outwards far enough to allow withdrawal of the inner joint from the box? Might need the track rod end disconnected too? Of course there's going to be a lot of gearbox oil you'll need to catch and then refill later and I don't like reusing oil in case it's picked up contamination from the casing. Maybe you could though if you pull the drain plug and let it drain into a clean container.
I never removed anything to get mine out, except for a few minor bits and pieces, bit of guarding, and pipe clamps. The hard bit, is getting to the top fixing bolt.
I've put the new battery in, started it up and the meter showed 12.67 volts so I'm guessing that new alternator is definitely needed.
