Theory sounds possible.The LP EGR is a composite unit. There is a butterfly throttle. I think that It operates in sequence with it's EGR valve to close off the air from the normal air filter to make the turbo suck exhaust, probably blends it. If this throttle closes AND the cooler is blocked there is no way that the turbo has a chance to make the inlet manifold pressure because it's strangled.
Question is, am I right in my theory?
see (basicaly now resolved apart from lingering injector doubtsHi, you have an MiL but no P0401, what fault code(s) do you have?
Thanks.
Hello@Geomore Can I suggest that you private message me with your email address and I will get in touch. I have changed certain components and have not had a mil light or limp mode since early December and can give you full detail. MES does record an intermittent fault but not sufficient to activate the MIL light. Fiat are well aware of these problems and are hiding away from it, another member has an ongoing claim now in its fourth week with no answer. The P0401 fault code is misleading when it says HP EGR blocked, its something else!!! 1/ you need latest Fiat software (v32) for the engine, update for Comfortmatic if you have it. 2/. I have changed the MAP and turbo solenoid AND I now only use premium diesel topped with Millers Diesel additive, (all to keep the injectors clean). 3/. I also changed the HP EGR because the fault code said so; there was nothing wrong with the original! so a waste of timeand money. There is a LP EGR and LP EGR cooler at the back of the engine, Fiat allow 6 hours using a ramp as its a subframe off job before undoing the power steering and removing the DPF. only then can you reach the LP EGR. Most likely the cooler is blocked with soot, I think mine must be however as i'm surviving with only an intermittent hidden code i'm current leaving well alone. I have my documented notes that I can send you so you can see what MES can show on your current problems. Members on here have these problems at 15k miles, mine started at 24k
MastiffHello
I have same issues with Euro 6 F1agl411D engine with 25.000 Km
The problem solved yet ?
Not good but good news im not alone.My car was make the check engine mode one years ago.First just 200 km then 100 and the last 20 km.In service change many parts turbo,wires,sensors..bid didnt solve the problem.This year change complete new engine (2000 km have) in Fiat Service.Now we drive 25.000 Km and the check engine come.up with these codes.At the Moment just the p401 Code stored 3000 km ago and no Flash Just stored.Now In Fiat service mechanicer say first change the egr Valve,sensor then Turbo.I didnt change these because now buy new engine and just 30.000 km have.in my engine.I would like first log with Multiecuscan and share here my logs.In short NO!!!
Unless you break your bank account open.
You can replace injectors and DPF and both EGRs and EGR cooler and MAP and turbo solenoid, cost inc labour £10,000 not forgetting you need software update 0032
That will remove you problems however lifetime not known.
You need to do a full read of this entire post to appreciate that many of us are working to work out how the system actually functions and what might help.
I rather believe that there are different failures which contribute to the fault codes.
As stated I've changed the Map, (factory fitted a wrong part); I've changed the turbo vacuum solenoid, these are believed to wear out at circa 25,000 miles. I've also changed to the 'ultra' high spec diesel boosted with Millers diesel additive.
I now only see P0401 intermittently.
I still suspect that my LP EGR cooler may be partial blocked.
Many of us now have a laptop with Multiecuscan to enable interrogation of our Ducatos.
Sorry not to have better news.
In short NO!!!
In short NO!!!
Thanx .I can log with free version or buy these Software ?Mastiff
Have you got the precise error codcode and symptoms.
For assistance on how to use it.
Ducato - Tutorial to Measure specific Engine PIDs (Parameter ID) and Save data for analysis.
This thread is for the general discussion of the Guide Tutorial to Measure specific Engine PIDs (Parameter ID) and Save data for analysis.. Please add to the discussion here. theoneandonly submitted a new guide: Tutorial to Measure specific Engine PIDs (Parameter ID) and Save data for...www.fiatforum.com
Hi, sorry to hear you’re another joining this unhappy group.Not good but good news im not alone.My car was make the check engine mode one years ago.First just 200 km then 100 and the last 20 km.In service change many parts turbo,wires,sensors..bid didnt solve the problem.This year change complete new engine (2000 km have) in Fiat Service.Now we drive 25.000 Km and the check engine come.up with these codes.At the Moment just the p401 Code stored 3000 km ago and no Flash Just stored.Now In Fiat service mechanicer say first change the egr Valve,sensor then Turbo.I didnt change these because now buy new engine and just 30.000 km have.in my engine.I would like first log with Multiecuscan and share here my logs.
The free version is very limited, its main use is to prove you have communication with your obd2 device. I bought mine from the UK distributor gendan.usb obdlinkSx I also have a bt vgate dongle. Cheap dongles do not always work with the Fiat extra codes.Thanx .I can log with free version or buy these Software ?
