Technical Ducato 230 LWR pinouts
angelroc83
Lombardia
Good morning,
I have a ducato 230 with pneumatic headlight height adjustment.
I managed to find headlights with an electric motor, and a tool for internal adjustment.
Now, both the internal instrument and the electric motors on the headlights have 3 pins. Can anyone tell me which are the +12V and the - ?
Thank you very much for your help.
Good morning,
Not the precise information, but Ihave attached the diagram for the x244, headlight adjustment. You should be able to confirm the pin allocations on the adjuster by measuring resistances with control at both extreme positions.
Headlight end may be more of a problem, unless others can help.
  • eLearn E3080 Headlamp Adjustment.pdf
Mythical! It's not the one in 230, but it can be a basis on which to think...
Let's hope that maybe someone with a voltmeter can actually test it on a 230 :)
Hi everyone, after a bit of trial and error I managed to reconstruct the connections. I leave the small diagram hoping it will be of use to someone.
