General Could you help me in identifying the exact model , size and specification of my new Ducato
elbahey
egypt
Thanks for being in the great forum
Model
ducato
2021
Mileage
13000
Hello,
The VIN is too new to be recognised by the forum ePER (spare parts catalogue) and ilcats.ru. Catcar.info doesn't even have the FIAT catalogue.
Looking at the 1st photo, I can see the following:
1st line below VIN is GVM: 4005 kg
2nd line below VIN is GCWR: 6505 kg
According to the internet:
Motore is the engine: F1AE3481D is a 2,3 liter Euro 5 engine with 96 kW / 131 HP.
The model line confirms it's a 4 ton GVM Ducato with the a.m. engine. It was produced since 2011. But of course had several liftings in the meantime.
Looking at the van photo I assume it's a L3H2 body.
The model has a FIAT codename x290.
Hi
For starters, the engine code indicates a Fiat 2.3 Multijet II Euro 5 emissions spec engine as used from about 2010 to 2015. Capacity 2287 cc, 130 PS power, 320 Nm torque.
The masses on the plate are 4005 kg Gross Vehicle Weight, 6505 kg Maximum Train Weight (i.e. with a trailer), 2100 kg Maximum Frint Axle Weight, 2400 kG Maximum Rear Axle Weight. This indicates that it is one of the Maxi series of weight variants.
Judging from the photo, the body size looks like Length 3, Height 2 (L3H2). If so, the wheelbase is 4305 mm, the length is 5998 mm and the height is 2522 mm. A tape measure will soon reveal.
Many many thanks 🙏 and i am very happy for your help ,
Thanks to be in this beautiful forum 🙏🙏
Hello,
I thought that an alpha in the vin i.e. P indicates it is a multijet 2 so is euro 6?
The euro5 is based on the engine model from the van's identification plate.
I suppose that what you're saying could be true for the EU / UK / CH market, that it should be the MultiJet 2 euro6 engine, but as the OP's van doesn't have the euro homologation number on the identification plate, it is definitely a model for a non-EU market, which could have the older euro5 engine only.
