how many miles on car?
several wear + tear things to rule out, some with AGE / some with USE,
Charlie - Oxford
Charlie - Oxford
Charlie - Oxford
Then I drove back home and tried to start it again and then nothing... No noise and doesn't sound like it's connected to the fuel pump
What to do now???
Classic.
Make sure the connections are good now.
Is the steering very heavy both sides?
For a start, check voltage when you have the steering light on (engine running)
Checked like the cables? Heh
Check voltage with running engine AND the steering light on.
(This is an alternator test not battery)
Yeah checked all the cables and tested to see what they were outputting
I've had this problem before and Ive put CITY mode on, then once I turned the engine off and started it again it would disappear.
... Now I had all the electrics checked and cleaned due to it playing up again...
Are you sure? Load tested?
I see there is the abs and steering light on... I can only think a bad battery or a bad ground cable.
It's a classic electrical problem to me.
Check again earth cables/ points,
I have had a car electrician to look at all of the electrics, who state that they're clean and fine.
Sounds like you've a power supply, or an earthing issue. To rule out the latter get a jump lead and connect it to battery -VE terminal and other end to a clean bit of metal on the engine block and see if she starts![]()
Okay I'll try that tomorrow, the earths are all clean as they've been checked I've been told
Connections have been checked, battery tested, key checked
Have you done what I've advised with the jump leads??
UPDATE!
I did a bit of investigating and looked at the earth points in the car... upon this I found the earth cable (gearbox) to be wrapped up in black tape and shoved into a cable lug!
I cut some of the cable to make a new connection and fitted it into the correct sized lug
Here are the photos from what I discovered...
I know! Unbelievable but my dads an electrician so we've made a good connection and its starts first time!
Is it only me that can see a theme here?:bang::bang::bang:
