Technical Car Stops while driving With Mesage Engine oil pressure low
Badal
Nagpur
Hello,
I have a problem in my car that it stops suddenly witha message on screen showing engine oil pressure low.. When I fill petrol to nearly 75% of the tank then car runs smoothly, and if fule level goes to nearly 60% of the tank capacity the problem starts. This problem is worse when the outside temperature is high (may be above 30°C) I have changed engine oil and oil filters recently.... But this problem is still coming and I always need to keep the fuel tank full... Any help please
Model
Grandepunto 1.4 fire emo 09, Petrol
Year
2009
Mileage
69000
That error is memorised in that split second the fuel is cut off and the engine stops. Otherwise, nothing can explain that error. There's nothing actually wrong with the oil pressure on the engine.
Absolutely. Oil pressure is a result of the stall, and not an issue.
We need to concentrate on the cause of the stop.
Crank sensor is a good shout, quick and cheap to replace.
When engine stops, turn the ignition off, wait a few seconds, then turn it on, just on, not cranking, and listen for the fuel pump to operate. It should run for a few seconds, then stop. If it is seizing due to heat, it will nto run immediately after the stall.
