Technical Cam shaft replacement - is it an engine out job?
People talk about easing a ridge in the inlet tract of the cylinder head to aid air flow. Mine feels quite smooth. Here's a photo showing the back of an inlet valve through the carb inlet. Where is this ridge?
If you put your finger into the inlet tract though the VALVE aperture, you will feel distinct ridge just inside the valve seat. Yes,it will be 'smooth', but it needs to be 'softened' quite a bit,which really only be done with a finger and various grades of emery-cloth. Remenber, the walls of the inlet tract only needs to be smoothish. SLIGHT roughness helps to actually increase flow. The exhaust tract needs to be polished.
Day 2 and I'm trying to remove the camshaft. If pulls out by 20mm then there is a thunk and if won't go any further. It will turn freely but there is something in its way.
I've pulled the fuel pump rod and the distributor. What else do I need to remove?
It was the crank counter weight. A small rotation of the crank and the cam came right out.
3 of the lobes are worn down to 5.8mm of lift, 0.4mm less than the spec. The No1 exhaust cam is worn down to 5.1mm of lift, down 1.1mm! Not only the lobe, but both sides were shiny metal. The shoulders of the other 3 lobes were still black with the metal just showing through in the middle.
That would seemto be the cause of your lack of performance! If you can afford it, I would suggest that (if the engine doesn't already have them) that you replace the 'concertina' push-rod tubes with 'spring-loaded' tubes. The last longer, are not so prone to leak (thinner 'spring' section goes to the top) and the head is easier to fit when using the 'spring loaded' tubes. They will compress enough that you can fit the head, do the head-stud nuts up a couple of turns and THEN insert the tubes---an easy one man job
No you have the seals for the 126 engines with the non concertina end push rod tubes.
I'm rebuilding the engine and have these two odd washers left in the box that had all the cowling hardware in it. Can you remind me where they're from please?
It lives. All is well. I'd knocked the 12v wire off the ballast resistor, but once fixed, it started and ran.
It sounds a bit different now, perhaps a bit more gruff. It sounds a lot happier below 2000 RPM, though doesn't pull any better down there. It idles more cleanly too.
I've taken is for a gentle test drive to warm it all up. Tomorrow I'll check all the nuts and bolts once it's cooled down.
To answer my original question - is cam shaft replacement an engine out job? No. I wouldn't even have thought it was so tricky that the extra work of removing the engine would have been offset by making it simpler. It was quite a lot of work, but none of it very complicated.
Well this has stopped being fun. Slowing down for a roundabout on a dual carriageway, there was a big bang and a flapping noise. One of the spark plugs has popped out of the head. It was about 300m from a Harvester. I managed to start it on 1 cylinder and coax if off the dual carriageway. I'm now waiting for the RAC.
I'd spotted that the threads were weak and bought a helicoil kit. When it arrived, the spark plugs fitted inside the helicoils with room to spade, I ordered an M12 kit as a replacement. These were way too tight, but had the right size tap to clean up the threads so I settled for that. Big mistake. So the head has to come off and be fixed up. Still, worse places to be broken down.
Edited for posterity. Both helicoil kits were junk. The tap and pilot drill was correct but the coils were way off size.
The RAC man suggested tapping the head to M14 x 1.25 and fit a larger spark plug, rather than have an M12 x 1.25 helicoil fitted. What would you do?
edited to say that the spark plugs are M14 x 1.25 and that the junk helicoil kits I bought led me to belive otherwise.
