Can you show a top view of the head just out of interestI've taken the plunge and removed the cylinder head. It all looks OK, save for the poor condition of one of the spark plug threads.
Is the damaged spark plug thread going to be repaired by a Helicoil (or similar) thread insert, or is it still good enough?I've taken the plunge and removed the cylinder head. It all looks OK, save for the poor condition of one of the spark plug threads.
Can you show a top view of the head just out of interest![]()
There are 3 good threads left. It might be a good idea to get it done.Is the damaged spark plug thread going to be repaired by a Helicoil (or similar) thread insert, or is it still good enough?
I was interested to see the size of the inlet port and as to whether it was 26mm like the 500 or 30mm like the later 126. Looks to be 30mm to me, thank you
If you put your finger into the inlet tract though the VALVE aperture, you will feel distinct ridge just inside the valve seat. Yes,it will be 'smooth', but it needs to be 'softened' quite a bit,which really only be done with a finger and various grades of emery-cloth. Remenber, the walls of the inlet tract only needs to be smoothish. SLIGHT roughness helps to actually increase flow. The exhaust tract needs to be polished.People talk about easing a ridge in the inlet tract of the cylinder head to aid air flow. Mine feels quite smooth. Here's a photo showing the back of an inlet valve through the carb inlet. Where is this ridge?
All outPush rod tubes and cam followers ?
That would seemto be the cause of your lack of performance! If you can afford it, I would suggest that (if the engine doesn't already have them) that you replace the 'concertina' push-rod tubes with 'spring-loaded' tubes. The last longer, are not so prone to leak (thinner 'spring' section goes to the top) and the head is easier to fit when using the 'spring loaded' tubes. They will compress enough that you can fit the head, do the head-stud nuts up a couple of turns and THEN insert the tubes---an easy one man jobIt was the crank counter weight. A small rotation of the crank and the cam came right out.
3 of the lobes are worn down to 5.8mm of lift, 0.4mm less than the spec. The No1 exhaust cam is worn down to 5.1mm of lift, down 1.1mm! Not only the lobe, but both sides were shiny metal. The shoulders of the other 3 lobes were still black with the metal just showing through in the middle.
They go on the small studs securing the thermostat housing to the cylinder head adjacent Tto the exhaust elbows.I'm rebuilding the engine and have these two odd washers left in the box that had all the cowling hardware in it. Can you remind me where they're from please?
