are you looking at the pictures correctlyNew discs are lightly zinc plated for rust protection. It quickly wears off (more likely burns off) but will affect brake performance until it does.
Brakes with the back side (inside?) of the disc corroded and mangled have suffered from too little brake pressure on that side. The only cause is they have not been maintained correctly. It might need a new caliper. More likely a full overhaul with new pins and bushes will do the job.
they have equal wear front and back the lip has broken off one side, look at the centre
i can pretty much gaurentee the groove around the centre is due the brakes being used very hard. Been there done that, had disc look like that, cost too much now drive like a granny. They now stay nice and flat. Just have to rough them occasionally as they tend to glaze,
you dont have to drive fast to destroy discs and pads, a lot of heat is generated if you only use the brakes to slow for junctions, leaving your foot on the brake while waiting for the road to clear doesn't help.
