My X250 3.0 from 2007 has this problem for over a year now, it seems not critical but I think I need to address this anyway:
When performing a cold start the alternator does not generate electricity. I can tell by the battery voltage staying at around 12-13V.
The battery light (E050) doesn't come on but the ECU starts revving the engine a bit higher to about 1100RPM. This is however not sufficient and I have to manually rev the engine to about 1200rpm, then the alternator suddenly kicks in and voltage jumps to 14V. Everything after that is fine, battery charges, no voltage fluctuations. With a warm engine this issue is less likely to occur.
I checked the D+ connection that is supposed to send some initial exciter current and I measure 0.7V until the alternator kicks in.
I had a bad earth connection before so I double checked the straps and the engine block has multiple additional connections to the chassis. Also, the accessory belt was replaced recently by myself.
Also interesting: if I rev too agressively the engine will stall and throw a code about the fuel pressure solenoid, I suspect because the battery can't supply the sudden change in current? Of course when the alternator is in operation this doesn't happen and the vehicle drives fine otherwise.
I could try and replace the entire alternator of course, but that job is quite involved and I would need to remove the axle etc...
