Lynseystringer
- Joined
- Jul 23, 2012
- Messages
- 2
- Points
- 1
Hi guys, just joined having bought a Ulysee last week from a little garage outside of Newcastle - was thrilled, needed a big car to cart my four little girls and hubby around in, that is until earlier this evening - The engine turns over but wont start, the key fob isnt working, so when I manually unlock the car and turn the key in the ignition the windscreen wipers come on and wont go off as well as the headlights, which constantly flash on and off even when I remove the key from the ignition - on the middle display it comes up with "engine immobiliser fault" the only way I have been able to sop the lights flashing/wipers wiping after removing the key is to disconnect the battery. Has anyone else come across this problem, and if so HEEEEELLLLLLPPPP what do I do? at the moment its just a rather large garden ornament thank you so much in advance if you can help me x
