ClareScott
Hello,
I have a Fiat Ducato 2015 2.3 Multijet.
It wont start. There's no rpm or fuel pressure.
The ECU has been sent to Cartech who have sent a replacement.
The crank sensor has been replaced, as has the fuel filter.
Its showing this fault code - P0335-29
I was wondering if you had any experience with this code. I've read it could be a continuity issue in the wire between the Crankshaft sensor and ECU.
Any help will be appreciated, this has been ongoing since October last year.
Thank you,
Clare
Thank you,
Clare
