Technical '06 Panda crank sensor issue.....
If that's the case I'll do it after i get the multimeter so we'd get accurate values unless you got me something to test with the BCM torn out of the car
Brown white
Brown green
Brown yellow
And brown black
I marked you the wires colors and the one that are possibly braided are:
Red-white
Black-white
Brown-black
As you can see in the 2nd picture
None of them
What about these
One looks like black and purple for the other network
But it's still
Solid brown and
Solid green
we are looking for
I have over a dozen different circuit diagrams
All are use the same colours
4x4
ESP
Post 2008
LPG
Dualogic
And so on
The upper 2 are on the brake pump and the lower 2 I don't know I'll check when i have someone to fill in
Does using continuity from the pins on the back of the bcm and finding which one on the ABS work?
Hello these are the wires you marked last time they refer to the oil pressure on the brakes and gearbox now there is this large plug that i think is for the gearbox want me to check the wires in it? Or is it definitely not and must check the looms on TCM? Now it is handy if we could find the 2nd 2 pins can related from the BCM. Got any idea which ones they might be if 11 and 20 are obd2 can low and high? Isn't it possible to be found through a similar diagram?
Now you asked for a solid green and solid pink wires found those in the plug on the bottom of the BCM with the headlights with (you can see how it is burnt before i got the car) anyway are those the wires you're looking for?
Oh and by the way got a new professional catIII catIV multimeter now all values are 100% accurate
We have two different networks we we can not find any, frustrating
C CAN and B CAN
Worse than that
The ABS should have two wires going in and two wires going out
Fiat have always used solid green and solid brown
They will be twisted pairs, and may or may not be shielded,
4 for one network and 2 for the other that 6 wires that's vanished
And we can't find the two wires on the ECU
It does not come out to the OBD port but ends at the body computer
Pin 11 and 12
Ok listen i can find them with continuity if we can find a lead like for example the ABS can bus is connected to pin 32 and 40 lets say so i prob, the 32 and start searching on the ABS. That's how i found the obd2 connector can and where they were headed it's easy if we have some sort of lead
But what makes it easier is my theory that the BCM canbus is busted because I'm still getting OL even with the new meter when i connect the can plug on the back of the BCM instead of as you said and showed in the video of getting 60 ohms
Remember fiat output the parallel canbus to the OBD, it stops at the BCM, we don't know what the resistance if any they should be
Which is why I ask for someone to check there's as I don't have my car here at the moment
Most other manufacturers output a standard serial Canbus to those pins
Which should be 60 ohms, this network on the fiat ends at the BCM pins 11 and 12 connector D here should be 60 ohms
Until you find the green and brown wires or confirmed C canbus wires on any node on the network you can't test the resistance on random wires and get a meaningfully result
