Technical '06 Panda crank sensor issue.....
It's not 0 ohms it's open 0L
Ok as for the can bus you asked for testing they all returned an exactly 0 ohms
just triple checking
Should be Black/pink and white/pink on all the wiring diagrams, no idea where grey and pink comes from, even more confusing
On the ECU
Are these pins Black/pink and white/pink
36 and 52
Man this car is so confusing I don't know who built it whether it was fiat or the aliens
Unfortunately fiat don't show everywhere on one diagram
And they use two different can networks B and C
Both of them go to most nodes on the nework
B Should always be black/pink white/pink
Should go to pin 6 and 14 on the OBD connector
That's the same for the 1.1 pre 2008 1.1 post 2008
And the same for the 1.2 pre 2008 1.2 post 2008
And the same for the dualogic 1.2
And the same for powered throttle
And the same for right hand and left hand drive
I no idea why yours is grey and pink
Well these were the errors i got when i tried it on all 3 available options in the can section
You can't measure anything untill you can find the high and low wires at a node
Measuring unknown wires will give meaningless results
Are you sure on pin 6 and 14 on the obd
Well it is universal to be there right? I mean the guy in the video mentioned and tested on them and you said so prior to that
Be the judge of the colors these are on the obd2 connector
One new finding: if the ECU is the first destination of these 2 wires then they are not headed there as i have used continuity on the both of them trying to find where they are located in the looms and not a single one of the ECU pins gave me continuity on the multimeter
