Technical '06 Panda crank sensor issue.....
They all seem to match except two
Pin 3 isn't fully in any photo only the white side not the green if this is correct I Would assume the pink and white is correct just misprinted
It's possible that due to the age it is looking more grey than white i don't know. Anyway i looked a lot and all manufacturers use the exact same obd2 pinout but the question is where is the first destination of these 2 can wires? Because they're not reaching the ECU
Can you not see the white/pink and black pink on connector H, I know it's a bit tight in there
You radio, the original was CANBUS operated if you follow the wires back can you see where a box plugged into the wiring loom, or a wire spliced in, either a can adaptor is fitted or an ignition supplier cable tapped into to operate with the ignition
Plug the ABS back in and disconnect the dualogic does the car crank
Can you now connect to the canbus via diagnostic software
Sorry mate removed the BCM and here's how it looks gonna check if the obd2 can bus are getting where you mentioned first
These are the wires on pin 11 and 20
Did this little trick and measured on the obd2 connector i got 0 ohms perfect continuity. Is it possible now that there is a canbus internal fault in the BCM?
The result isn't what I expected, before jumping to conclusions we need to confirm what a working car resistance is first
Fiat is a little different, it uses the BCM as a gateway, unlike most
Alright then waiting here hopefully it's not what i am expecting but I'm already prepared for the worse (which is a new BCM and ECU)
One more thing for today:
I tested for voltage on the canbus obd2 plug got no voltage at all between low and high but i plugged only the BCM plug that contained the can nothing else should i plug them all again to get a reading?
And i am promised a professional multimeter tomorrow probably in the afternoon then we will be able to measure 100%
Those multimeters are fine for this sort of thing
The Panda has 2 separate networks
This B CANBUS network is in parallel, every node does not have to be plugged in but you do need all the powers and grounds connected
Black/pink and White/pink
I have no specification for testing this network
Had a look at the 500 diagnostic port as I have more information on this, it's completely different
The C CANBUS is serial anything after a disconnect node will also not work
Brown and Green
The ABS should be in the middle with 4 wires
Brown, green wires going to the ECU
Brown, green wires going forwards through other nodes ending at the BCM
Split anywhere green to brown should be 120 ohms
I mean shouldn't i get a voltage reading if i plug the can included plug only? The loop is closed and i should get one
