- Joined
- May 15, 2011
- Messages
- 3,769
- Points
- 568
I'd like to say that I'm really enjoying this thread especially with the sheer technical know how from yourself J333EVO and jimbro1000. You certainly know how to 'push cars' and have discovered their 'weak points'.
For the 'normal' driver out there (I might come into this category
) who has yo yo'ed from a fairly standard engine to a turbo charged engine and then to a 6 cylinder 2.5L engine (you can guess which one - rear wheel drive) I have ended back into a decent little engine with the option to move back into a turbo charged little engine.
Abarth have used a Variable vane turbocharger which gives the best of both worlds (this was used in the 911) delivering a good spread of power with little lag. It's as if its 'part of the engine'.
Remembering the choice that used to existed on the cossies with either a T3 or a T4 (all or nothing) the newer technology means you can get the best of both worlds.
The issue on boost pressure is also linked to increasing the size of the intercooler but it was an interesting point.
On the VTEC engines there is some inputs from other reviews not dissimiliar to my own.
http://www.japmobiles.com/cars/cars_detail.asp?id=14
The ITR begs to be driven and is rewarding to do so. It does require dedication, with little low down torque, and VTEC not even engaging until around 6000rpm
This review will probably upset you a bit…
http://www.timesonline.co.uk/tol/driving/jeremy_clarkson/article1839477.ece
and I could dig out one from EVO which was similiar to the former in relation to the Honda S2000.
Renault ironically were one of the first hot hatchbacks with the Renault 5 in turbo charging it and now they're the one with a NA engine in the Clio. Going back on the VTEC and their slick gearbox -if this was put into a Turbo charged car I wonder how it would cope.
There is a demand out there for a nice slick gearbox (preferably 6) in the A500 but thinking back on the review on the DS3R where Chris Harris said that if you want an advanced small performance car you are going to have to pay for it.
On the original reviews of the A500 it was priced around £13,700 on its launch year (I could be wrong on this) but prices have been creeping up possibly due to VAT increases and possibly also because some of the new drivers of the A500 expect Beamer service levels which drives up the overheads hence cost.
In Ireland Suzuki is very poor at holding its value. A 2006 model Suzuki Sport (65K on the clock - pretty good condition) sold at Windsor Auction in Feb this year for €2,200. Hard car to shift on - its amazing how countries differ. Although this has a 1.6 engine to get its 120bhp.
As a road car IMHO the A500 suits the current PC environment and if the MA is stuck into it you will have a 150 bhp + in a car weighting a little over a ton that will return upwards of 40mpg and should be priced at under a £15K. If you want a bit more oomph in it - it can be TMCd for around £300.
Hopefully Fiat will continue to develop the Abarth marquee and not 'switch off'.
