we make it far to complicated
modern pads nearly always come with the shim already fitted and ready coated, black rubbery coating
pads should be loose. If they are not either some dirt it still in the groove or the paint has blobbed around the lug from being hung up to dry
red rubber grease is for assembly where oil or fuel is present not for guide pins, only place I can think of is fitting a new calliper O ring
copper anti seize, there's load of different types, but "generally" is not suitable it normally designed to err anti seize not lubricate
the correct lubrication always was silicon grease, its what was always supplied in a little sealed packed when you bought pads or guide pins. Although more specialised read expensive options are now available
I have had two Pandas one over 200K the other 170K sticking or rusty brakes have never been a problem once they have cleaned and serviced. I fit the pads dry. Your mileage might be different if you live in harsher environment. But the recommendation from brake manufactures in the past has always been silicon grease and only on the contact points and sparingly, this has changed slightly as some brake manufactures now supply the own brand "specialised" grease for a cost.
Even in city you should an easy 50K out of the pads maintenance free
plenty of video on YouTube slavering loads of anti seize on. Including well known companies that should know better
