Hi mate
I am a newbie.
I have been reading your posts and received replies.
I admit that I did speed read your posts and replies, so I think I might have missed something. So could I politely ask a few questions about your problem and your testing? I am asking as I have the same problem with my 1.6l cabbie.
Long story! But basically. I sorn it to do a bit of a re furb on it. I kept starting her and letting her idle for 20mins or so while I was on with other stuff ie life and work
. For some reason it wouldn't start and hasn't started for over a year now.
My questions are did you replace the. Plugs and carry out the same test for sparking on all the new plugs?
Have you tested the fuel pump and fuel supply and the fuel bar?
Do you have a pump, engage noise when you turn on the ignition. On on one of my cabbies I could hear the pump and the pump relay click in.
I don't think you have a blown gasket!
As you haven't mentioned any one of the tel-tail sings of a blown H/ gasket. Oil in water coolant, water contamination in engine oil, loss of water coolant, over heating, sludge in and around oil filler cap. One of the above is a good indicator for a blown H gasket.
Also, your pictures give no indication of a blown H gasket. Yes they show damage ,carbon and oil deposited in the combustion chamber BUT that is to be expected for a old car that hasn't been loved. One other big thing that leads me away from a blown H/gasket on your cabbie is your pictures of the cylinders !
If you had a blown H / gasket your pictures would have shown at least one pot that would be almost clear or clean of carbon deposits.
I would have thought that the damaged spark plug would have been your problem? And a simple fix for you?
I have replaced all the relyes on my cabbie with no joy
and my pump is silent!
I don't think I have a broken plug or the timing is out? My next move is to look at the plugs as a precaution and test the HT lead the same way you tested for a spark on your plugs ! In The dark ! A damaged HT lead can sometimes light up the engine bay like a firework, most times it's a faint spark. If the ignition is turned on without turning the engine you may hear a click noise with the spark.
I am firstly going to test for a bad earth for the pump. Then plugs and HT lead test.
Hope you get her started up soon.
