Lostmykeys
i got a wiper linkage repair clip on my punto, works very well have not had a problem with it now.just check you youtube video of how to install
,i declined his offer of doing the bodge and noticed the arms were held on with sellotape
Has anyone tried this repair using one of the wiper linkage repair clips? (ebay it if you dont know what i mean)
Passenger side linkage has fallen off and want quick fix but not too keen on crushing the hole.
Hi Guys,
My punto drivers side wiper just stopped working so have ordered one of those repair clips from amazon. I fitted one on a micra and is working fine. Just one question - is it easy to access the linkage on my punto - have not had a look yet.
Many Thanks
Hi - ok cheers for that, will i have to remove the linkage or will there will enough space to fit the clip in situe?
Cheers
Hi There,
Did you manage to fit the clip without removing the whole linkage? BTW i have 2004 active.
Cheers
ive done this before it don't last long in rainy seasonFree Fix
Fixed my driver side with a Cable Tie (CT)
Position the wipers at their highest point on the windscreen.
You will see there is a hole through the uppermost link about 4mm diameter. Thread your CT through this hole until the large end of the CT won't go through the hole..and position it so that the "underside" of the CT is facing towards the engine..... (that means.. to finish the job, you will be pushing the thin end of the CT from the engine side towards the windscreen through the eye of the CT).
Connect the link (that is falling off) onto the the balljoint of the upper link.
Then bring the thin end of the CT from underneath towards the engine, up and over the link that is falling off, around the back, down, and underneath to the front, up again and thread it through the CT eye.
So you have made an infinity loop or figure of 8 with the CT.
Tighten it, pretty tight but not too tight.
