Remember fiat output the parallel canbus to the OBD, it stops at the BCM, we don't know what the resistance if any they should be
Which is why I ask for someone to check there's as I don't have my car here at the moment
Most other manufacturers output a standard serial Canbus to those pins
Which should be 60 ohms, this network on the fiat ends at the BCM pins 11 and 12 connector D here should be 60 ohms
Until you find the green and brown wires or confirmed C canbus wires on any node on the network you can't test the resistance on random wires and get a meaningfully result
