Technical '06 Panda crank sensor issue.....
We have a key code
We have RPM signal
We have compression
We need to go back and test spark
The most reliable way would be to take a HT lead off something like this
On yours just do one from each coil pack
Keep your hands out of the way, as long as the spark has an easier route to ground you will not get a shock
Charging the battery right now I'll keep it till tomorrow and will use a metal screwdriver and make the spark short to the engine
Couldn't put the battery on the charger anymore so i took it and got someone to crank it for me didn't get a spark neither with an old working spark plug nor with a screwdriver shorted to the engine
You mean a multimeter on voltage and check on the plugs of the coils?
Yes
I was just about to checking the wiring colours
There should be one wire going to each coil that's the same colour this will be the supply
Should be battery voltage at ignition on, may switch off after a few seconds
Blind aim lol hope the colors are clear
Hello there and happy Easter (not sure if I'm early)
I went ahead and measure the coil packs while their plugs were disconnected this is the value for the pack in the front and the rear one gave 0.04-0.05v around this value
And on the one in front if you could see the color it turns out the value between the negative and the yellow/red cable not the brownish one that gave 0 and I'm not sure about the rear plug as it is still covered (didn't remove the tube holding both wires) but i did get 0 and 0.04-0.05v
With ignition on it should be battery voltage on the brown and red
We need to trace it backwards
Unfortunately I don't have an exact match for the wiring probably due to the smart gearbox
Back in a minute
It's a fairly simple system
Relay, fuse and wires
There is a another join
Between the two brown and red wires should be close to 0 ohms with the battery negative disconnected
I think I'm going to go get a sandpaper and start by cleaning all my fuses
