I am out tomorrow morning with no internet unless I find a cafe
NormalBottom right pin: ignition off: 12.20v
Ignition on: 12.01v
Cranking: 9.95v->10.00v
Bottom left pin: ignition off: 12.20v
Ignition on: 11.99v
Cranking: 9.57v->10.07v
Top left pin: ignition off: 12.20v
Ignition on: 11.98v
Cranking: 9.53v->9.85v
Top right pin: ignition off 12.20v
Ignition on: 11.97v
Cranking: 9.37v->9.81v
Hello everyone hope you're having a nice weekend/holiday, these are the values i got after taking a lot of time making sure by probing from behind but keep in mind that on and cranking are dropping after every crank and second value while cranking is after about 2-3 seconds of continuous cranking hope these values clears any suspicions but now they seem normal to me
Does that mean it's different to hereBottom right pin: ignition off: 12.20v
Ignition on: 12.01v
Ignition on: 11.99v
Ignition on: 11.98v
Ignition on: 11.97v
The meter must have been okay here as two of the four wires were okayWhile plugged ignition off the 2 on the left are giving battery voltage with the red and white but the 2 on the right are giving 9.6 and 9.3 v up and down respectively
No no forget the old one for some reason it you don't push the prob extremely hard you won't get a right value so apparently last time i didn't push the prob all the way in because this time i was sure because i started with ignition off getting the same battery value then continue with ignition on than crankingDoes that mean it's different to here
First the door was closed and the pumps had filled their pressures and went out, so these spikes came with only ignition on while I'm sitting in the car nothing elseView attachment 440796
This noise needs addressing
Without a clean power and ground, the sensors and communication will not work
Even if the door was opening and closing it should not drop as much as cranking
If you just switch the ignition on and leave it
Does it settle down
