One more thing is that the insulation came off midway down the engine and was repaired and having heard a lot how bad fiat wirings are i didn't want to take a chance so i replaced about 6 inches of the wires that had the copper with slight corrosion starting to build up so I changed both segments off the wires both the signal and ground as i read on the internet but apparently the oil sensor wasn't firmly seated I'll try and make sure tomorrow and will send you an updated video and this one is from before we started messing with the ECU so you can say that this is the main way the car used to behave because today i searched all day between the ECU and cps and there's a lot still disassembled.
One more thing that could help us that the check engine light has always been slightly dimmer than it should be because of i give order for it to light up through the scan tool it lights slightly brighter than shown in the videos
