Running RCA Through
You've not sorted most of the power. You now need to sort the signal side of things. At the HU end, on the back of teh HU there should be 2 RCA output ports. Plug 1 end of the RCA cable to this.
Now you need to run the RCA cable to the amp. Again shouldnt take long if you prepared correctly. Make sure that the cable avoids all powersources as possible as it would interfere with the quality of the amps signal. Garbage in surely means garbage out!! When the wires run through, plug the RCA into the input ports of the amp.
You can now also put back teh remaining trim and dash components as thats the last of the cable running.
