Finishing Up
Ok now you can reconnect the ground terminal of the battery. Leave the fuse out of the wire for now. At the amp end, wire in the speaker wires however you want your setup to work. (not covered due to many different configurations depending on amp use). Plug in the fuse in the power line. If it goes bang, cry But it shouldnt... If it does, you've got a short somewhere - probably where the wires run through teh bulkhead - check the wire for cracks in insulation.
