What You Will Need
What You Will Need
· Marea Poly Elliptical Headlights
· 2x Junior Connector 2 way female
· 2x Junior Connector male pins
· 1x Crimping Tool
· 2x 4mm diameter ring connector
· 2x small rubber grommets
· Wire (earth 72cm total)
· Wire (Positive 92cm total)
· Heat Shrink tube (18cm each side)
· Black cable ties (small)
Make sure the male pins you buy are like this one. Not the ones with two fixing wings.
The male pins PN:192174 can be bought at Vehicle Wiring Products.
Be sure to buy the correct ones. I already made that mistake so you don’t have to
http://www.vehicle-wiring-products.eu/VWP-onlinestore/connectors/housings.php
The Junior connectors are also available from The Toolbox Shop.
http://www.thetoolboxshop.com/
I had to order Heat Shrink tube on eBay. I could not find long enough lengths locally.
The Range has a motorfactor stand with the cheapest parts by a long way.
