Preparing the Lights
Remove the grey light covers. Take a look at the Main light connector you can see three pins and a hole where the Bravo has the sidelight pin.
Remove the male connector. I used the biggest screwdriver to hand. You can see securing clips on all four edges of the connector.
Now the hard decision. Where to bring the wire back out of the light and to the sidelight plug.
There is a lot to consider. Clearance for the lens internally and being sure you don’t effect the strength of various mounting points. Also clearance for the covers and adjuster motor.
You can see in this image where I have decided to drill a hole for the wire to come out (marked in blue).
And here it is with a grommet. The size all depends on the gauge of wire. I made an 8mm hole. Double check everything make sure the hole will not effect the cover. When drilling I put masking tape behind to help catch any plastic swarf.
