- Joined
- Sep 29, 2013
- Messages
- 467
- Points
- 177
Can anyone tell me if this is the right plug ? Colours are slightly differentView attachment 206537
I thought not, initially. But it could possibly be the one, it is missing the aircon wires (yours does not have aircon then?) which may not be fitted to all, as Communicators van does not have aircon, yet has the wires- maybe not all do?. The colours of the 4 wires look like, IIRC, mine. You could find out for sure, by tracing them to the main engine ECU. It is a 2 person job, ideally, one to hold a multimeter probe on the relevant ECU plug pin in the engine bay, and one to place the other probe on the terminal in this plug, after you have disconnected the two halves. You could do it single handed, making something so one probe fits into the black plug socket pin hole and will stay put, then go outside and place the other one on the ECU cplug pins in turn, noting continuity or not. You will need long probe leads!The ECU plug pins you need to check for continuity from your black plug inside being 53, 54, 55, 56, and 57. I don't recall which colour is which pin, but for now all you need to do is find if these wires are the right ones. This will give you a 100% sure way of knowing you have the wires in the dash for a relatively easy install- certainl loads cheaper than an aftermarket unit!
