- Joined
- Sep 29, 2013
- Messages
- 467
- Points
- 177
I have got the brake switch out!
I disengaged tthe connector tab, rotated the switch off its bayonet so as to tilt it (tried this before tho'), and let my temper out on pulling the plug out. It gave, so then had room to get the switch body out. The tit on the new swich was as stated too long, so I cut off the rounded head and the short square section belw it. It is neow exactly! the same length as the old one. Getting the new one back will be hard I expect. BUT I hve managed to get theintermediate piece of loom out, about 6 inches, with the switch plug one end, and a socket the other. I can solder now in comfort before running the replacement gauntlet, at least.
So to be clear- I now bridge wire switch pins 1 and 3, spurring off this bridge to yellow stalk cable? Pins 1 and 3 being normally closed and check out thus for correct continuity, going openwhen brake is pressed, and the oppsite on 2 and 4, for brake lights. Will, therefore, 1 and 3 bridge supply my + swiched voltage- internally from pin 2 or 4- or do I need it from elsewhere? I know I keep asking the same old stuff, but I'm bouncing off walls here with the frustration of a job I wished I had never started!
