Technical Wiring loom
Steady1234
Medway
Hi all advise needed
2.2 Peugeot boxer 2014 need to fit a new Engine wiring loom, it’s been damaged, the loom number is. Bu3t-12b637 underneath that is CBF
Is the cbf relevant as the same loom numbers have different numbers cca/
Hope someone can advise
Thanks .Steve
Hello,
This seem to be the Ford part number I assume.
FIAT in the x250 has 3 wire looms in the engine compartment with the 2,2 engine. 11 different looms marked as 1 and 7 marked as 3. Depending on the van options. The FIAT part numbers are blue on the screenshots. I assume you're looking for the one marked as 3. If the diagram is relevant.
But I'm quite sure the parts shall bear two numbers for both computer systems in both factories.
EDIT: And I've just realized there are 3 different power versions of the same 2,2 engine. 74, 88 and 93 kW. That shall help narrowing the choice a little bit. Unless yours is 88 kW :D
Thanks for your reply I’m looking for the one that comes from the ecu and goes to the engine
