Technical Where does this plug into
GenghisK
Liverpool
Hi all
Found this plug in the front drivers side of the engine bay tucked in very close to the cam belt (top by cam shaft)
Also when idling what should the temp be as mine today went to near 100 degrees:confused:
and when it was this hot i put the heater on and it wasnt hot I waited for a bit and it went warm then cold again???
Any clues
Hi
Do all the above but also check the fan will spin freely by hand then that if you give it 12v with two wires will spin up like a tornado, then remove the conector from the radiator temperature sensor and short the connectors with a paper clip., it should spin up again, any fails you need to sort before driving...
In traffic the fan should be off and on like your tail lights.
Other wise you will need to change the head gasket for sure...
Noel
