I quite often have this happen with mine if I’ve just had new tires or have recently pumped them all up and the weather has changed, quite often get it if we go over to france as well probably because I have checked the pressures just before going and pumped the tires up to a higher pressure than normal and the tps gets a bit confusedIt's a different place to Mazda that's for sure...could have them tomorrow if your didn't care about brand or speed and weight rating otherwise usually 2 or 3+ days if you wanted the exact ones.
This 2 minutes on the internet Sunday morning, fitted by Monday lunch and an exact swap for the ones on the car.
Could probably have left the slow for a while but I'd already ordered the replacement by the time I'd investigated how bad the other one was. Was fully expecting wild hissing once the screw was out...hence taking it out as knowing the other half she'd have mounted the kerb going past a car in the street and removed it forcefully.
There tends to be common dimensions in each diameter oddly enough usually around what VW group and Ford use (mysterious I know!).
Of course despite my best efforts the puncture alarm went off on the smart motorway today....at the bit where the M6, meets the M56 meets the M62 so all off ramps lead to other motorways for about 5 miles.
But false alarm caused by half a psi difference across the front and the diameter difference (brand new tyre Vs one that's been on the front for 12k) across the axle. Stressful few minutes...but behaved itself once checked and reset.
New tyre now has 500 miles on it...
