Hi guys,
I just finished the install of a Wesfalia Tow bar. It was pretty straight forward, this is my 3rd tow bar ive installed ( first with the universal loom, my others had OEM looms and dongle for coding) , I made sure any bare metal was sprayed with rust inhibiter primer, and also used silicon , just like OEM.
I purchased the Wesfalia kit with the 13 pin universal loom. As the only one that came with an oem plug in loom was for a 7 pin. ( i need a 13 pin, i use my trailer for work.)
Anyway i am wiring the loom and i am up to the last pink wire coming from the control unit. It says i need to find my OEM PDC, ( i found it its a Bosch unit , hidden in the rear left pillar.
The instructions say to cut the earth to the OEM BOSCH PDC and connect it to the Tow bar module so the reverse sensors dont go off while i am hooked up.
Has anyone done this before. ? Any help will be greatly appreciated.
I will try and disconnect the EARTH tomorrow and see if it works.
I have attached some photos.
Cutting the earth on the PDC does make sense, the module im guessing disconnects the circuit once the trailer loom is plugged in. Im just not sure if the black wire coming out of the OEM BOSCH PDC is the earth cable. if no one has done this before im going to have to try tommorow.
