Technical Vss location and wiring modification help for Punto 188 mk2 1.2 16v elx speedgear non
But why it is available to my car when checked by entering VIN in fiat eper.?
Find the diagram in eper that shows the part you are looking for then look for it on your car.
If you enter your vin into eper it will not eliminate all the parts that weren't fitted to your individual car but will rather show range of all parts that may have been used on production line when your car and similar models were built. In the eper lists there are loads of additional notes specifying different engines , gearboxes, markets, options etc etc
Sandaru, I read the guide by T14086 who was the first to mention the VSS wiring modification in the VSS EPS thread
https://www.fiatforum.com/punto-mk2-2b-guides/70703-punto-steering-column.html
"If your steering light has/is on it might not be steering column related,a faulty vehicle speed sensor (or sensor wiring) fault will bring on the light it may also bring on the engine warning light & even stop the speed from working.A error code (P0500) will be logged in either the steering ecu/fuel ecu or body computer.
If this is the case a wiring modification (carried out by dealer) from the speed sensor to the fusebox can be carried out...problem sorted."
It is also clear the VSS fault which can be solved by changing the wiring, originates when the car is first switched on while the EPS ECU is booting up. So from my reading of that problem, restarting the car can remove the fault and it never comes back while the car is running but it could come back again next start/turn of the key.
If I was you I would reinstall all of the original parts and see if you can get back your original fault code. Then only change the motor. Have you tried that yet?
Body Computer connector C
1 Reversing signal for steering column switch
2 Not connected
3 Screen
4 Immobiliser CODE aerial
5 Immobiliser CODE aerial
6 ABS serial line
7 Speedometer signal from ABS
8 Front fog lamps relay R14
9 Main beam relay R2
10 INT supply for speedometer generator
11 Not connected
12 Not connected
13 Headlamp washer switch on column
14 Headlamp washer relay R17
15 Earth for speedometer generator
16 K-line for ABS
17 Speedometer signal from pulse generator
18 Brake fluid level sensor
19 Alternator +D signal
20 K-line for ECU diagnostics
21 RF aerial earth (another source states pin C3)
22 Not connected
23 Not connected
24 Bonnet open switch
25 Alarm siren serial line
26 CAN-bus A for electric steering
27 CAN-bus B for electric steering
28 Repeater for speedometer signal
29 ISO5 interface - immobiliser and ECU
30 Right front sidelight
31 RF aerial (another source states pin C1)
32 Not connected
33 Not connected
34 Alarm supply (alarm siren)
35 Preparation for aggregates 2 (K-line for diagnosis)
36 CAN-bus A from ECU
37 CAN-bus B from ECU
38 Left front indicator
39 Right front indicator
40 Left front sidelight
Run a wire from the VSS signal output wire to pin 17 of the BCM connector C as shown in the picture, the other two wires on the VSS are +12v and ground from memory.
If the pin 17 in the blue plug is blank you will need to take the cover from the plug and insert your VSS signal wire.
Refer to my old post for wire colours if needed.
Here is some information I found from another member of this forum, I am not sure if the EPS steering has any input from the VSS ?
you can easily test the electric power steering unit using a car battery and a multimeter.
there are 6 wires:
black - earth
white/red - live (12vDC)
blue - ignition live (12vDC)
purple/black - city mode switch (live or earth to switch modes)
pink/white - signal for City mode light or steering system light on instrument cluster
pink/black - signal for City mode light or steering system light on instrument cluster
first you need to determine which of the 2 pink wires is for the city mode light. to do that wire up the live and earth and ignition live. now use a multimeter (black terminal on earth, red terminal on wire) on either of the 2 pink wires and try switching the purple/black wire live and then earthed then live then earthed etc. check to see which of the pink wire's signals switches on and off as you do this.
the wire with a signal that switches on and off is the city mode light wire. you then know the other wire is for the steering system light.
now attach the multimeter to the steering system light and disconnect the blue wire from live. now reconnect the blue wire and check that the steering system light wire has a signal for a couple of seconds. if the signal stays on it means there is a fault in the electric power steering unit. if the signal switches off after a couple of secs it means the electric power steering unit is working fine.
Wiring diagrams with key for 2000 model Fiat Punto 1.2 Speedgear (y)
