cotswoldtony
- Joined
- Dec 10, 2015
- Messages
- 46
- Points
- 11
Moderators Note:
I've started this thread to put all the currently active dualogic failure posts into one place.
The story begins here...
Hi All
Newbie here!....
I purchased my Fiat 500 dualogic new in 2010.....roll forward nearly 5 yrs & apart from a couple of minor niggles I find myself with the prospect of a new gearbox needed
Over the past month my car had developed the tendamcy to hate changing into reverse, flinging itself into neutral whenever it felt like, including a terrifying incident at speed when suddenly brakingDriving in auto or manual mode did not seem to make a difference...
Off it went to dealer who after a few days of diagnostics & road tests cleared the ECU memory & other stuff (apologies as I am no means converse in the ways of cars!) ......fast forward & after 2 days it all started happening again...
Back to dealers & now they've stated it needs a new gearbox!!.....at the cost of.........£1300!!!
They suggested I rang Fiat Customer Care which I did today & they have opened a "complaint case" for which I have a ref number & one of their team will contact me in a couple of days....
Is there anything else I can do!?!....
Ps.....car has only 22,000 on clock & FSH
Many thanks for reading!
Sarah![]()
:bang:
Hi I am a New Member,
My partner has a Fiat 500 Dualogic and I had to explain to her that it is not an automatic gearbox so it will not drive like other automatic cars she has driven.
The Dualogic has the M20 AMT (Automated Manual Transmission) gearbox which does not need servicing like the modern Tiptronic Auto Transmission so it has cheaper running costs.
The M20 Gearbox is very reliable but the operating system like most vehicles today is via an electronic TCU (Transmission Control Unit).
The good news is the working components are fitted to the outside of the gearbox and rarely does the gearbox need to be removed.
I have pointed out to my partner not to slam the driver's door as the gearbox pump switch is fitted to the door catch assemble so opening/closing the drier's door turns the transmission pump on and off.
I can only point out main agents will reset the TCU and replace expensive components to fix a Dualogic.
My partner's Fiat Main Agent did not even know her car was fitted with the M20 AMT Gearbox when she asked if they had serviced her automatic transmission on the major service.
I hope this helps.
Regards Tony
