so it works????where was the dry joint?
Dunno whether it works yet. Found the dry joint in one of my solder joints (oops) on the connection between the torque sensor and ECU.
Going to the shed after lunch.
double bugger
You say that just as i'm about to under go a re-wiring spree :bang:.
whoot whoot.
Never trust italian/polish wire colours.
good stuff! is it all working? pas seem good?
what was the problem/s then?
ahhh at least it works and never gave you the blue smoke of death.
no problem and hope it helps on events![]()
As promised, the few wee jobs nearly done. Only the full beam issue to sort out.
Steering working, all the dash bolted back in, managed to make the horn work with a cvurly cable.
Its quite wierd putting it back in the shed and being able to twirl the wheel.
You sure your work shop is not iced up?
So when can i book mine in to have it fitted lol
