Technical swap engine perhaps
barryfiatman
FRANCE
We have a 2005 Fiat Multipla with the 1.9 115hp engine at 239,000 kms.
Just wondering if a 2.9 twin turbo Alfa engine would fit in instead?
Has anyone done it already?
Sorry, when you said the Tipo chassis I was thinking of my Multipla, not the Tipo chassis that was used for the 5 cylinder engine.
The multipla was on the Bravo chassis. Sorry
Have you found any info? What It Need tò be changed tò drop in the 5cyl in a 1.6 multipla? Should i buy Engine mount from the 5cyl coupé?
Can i change also the gearbox?
What about the axle?
How Is plug and play?
The ECU side? Its easy?
It is possible to find online information about projects created (and completed!) by Polish mechanics: successfully fitting the 5-cylinder 20V Fiat Coupe power-unit to a Multipla AND successfully fitting the Alfa Busso power-unit to another Multipla.
