General Speedsignal 2007
Granduca
We have an 2007 Ducato and im looking for the speedsignal (tacho signal) for my navigation system.
I also look for the reverse signal
regards
Carsten
Do you mean the speed signal in to the built-in sat nav (Connect) system or are you trying to fit a different one? Same goes for the reverse signal. I can probably tell you what pins they are on in to the Connect system but otherwise it's a bit tricky.
I have a Blaupunkt EX-V DVD navisystem. and for this i need the speed and the reverse signal.
I found the Speed( tacho) signal. But where do I find the reverse signal ( +12 volt when my Duc is in reverse )
Finding the speedsignal i can point to my homepage. Sorry its in Danish but im sure you alle understand the pictures. www.heintzelmann.dk/womo Click on TIPS.
Regards
Carsten
