To get an idea as to how each brake is working. Jack the car up crack the wheel bolts, your hand brake should be adjusted to about 5 clicks till the wheels won't turn even if you grip them with your hands to try to rotate them. The one that does turn will obviously be the one that needs adjusting. Remove wheel and drum and adjust. Put the drum and wheel back on (2-wheel bolts will suffice) and go through the procedure again till you get them both the same, eg balanced. My adjusters don't seem to self-adjust so once a year when servicing I do the above procedure and for the last 3 years the car's passed its MOT. You can also do this procedure with say 3 clicks on the handbrake so the brakes start to bind then check which side isn't. This is the method I use, but in your case, you need to do the first method to make sure the wheels will pass the rolling road test for the MOT.
With hindsight you'd have been better off buying the complete kits already built up with the adjusters in place.
But hindsight's a wonderful thing as we all know. Good luck.
