Technical Panda 4x4 rear wheel bearing and hub
scott73
Weston
I have a Panda 2010 4x4 1.2 and wanted to replace the rear wheel bearing, at first i purchased just the bearing which I still have but then read its best to replace the whole hub and I could do this myself as no press is needed. The hub arrived but its not the same size as the bearing, the bearing is 35mm and the bearing in the new hub is 30mm.
Links to the parts
Bearing https://www.eurocarparts.com/p/starline-wheel-bearing-kit-628650239
Hub/Bearing https://www.partsinmotion.co.uk//ca...rint-wheel-bearing-kit-rear-adbp820008-detail
I know i can take off the old hub to check but I use the car for work daily and can't wait for a mechanic if I can't get the hub.
Anyone know what its is on a 4x4 (35mm or 30mm) and if so have a link to the correct hub/bearing kit.
Model
Panda 4x4
Year
2010
I believe the hub is 7672265 and 35mm
