Technical Reaching Starter Motor on 1.3 Multijet 4x4
Dr Zhivago
Chepstow
How easy is it to reach the starter motor electrical connections?
I have an intermittent starting problem. Sometimes it starts fine, other times I just hear a click (presumably an under-bonnet relay) but no starter churning. I does start eventually but it can take six attempts. This is Mrs Z's car and she is getting worried to use it in case she gets stranded. The battery is OK.
Some previous threads have suggested corrosion or other poor contact at the starter's electrical connections, so that is where I want to start. I understand it is down the back of the engine and that does not look easy to get to. Can I get to the connections from the top, after removing battery etc? Or is it accessed from underneath? - I don't have a ramp, only axle stands.
If the connections are OK, could it be that the relay I can hear is failing? Is it within the starter motor or elsewhere under the bonnet? Any help would be appreciated.
Model
PANDA 1.3 Multijet 4x4
Year
2013
Mileage
25000
the access is from underneath with car on a lift
Well, I have had a look underneath (I don't have a ramp, only axle stands) and I can't even see the starter motor and even if I could there would be no room to get my hand or a spanner up in there. This is a 4x4 and there is a large lump of a casting on the back of the engine/gearbox which presumably houses a bevel gear that powers the propshaft to the rear, and I guess the starter motor is above that somewhere. I might see a bit more if I remove the skidplate under the engine, but I would expect the starter motor to be to the rear of that. There is also a large engine mount arm that extends rearwards from the bottom of the engine/gearbox that looks as if it reacts the engine torque, and this is also much in the way. And the exhaust pipe of course.
Maybe you are meant to remove these obstructions to get to the starter motor in a 4x4, which will be a real mess, or maybe the whole engine must be pulled out which means it will need to go to an agent's workshop.
It's accessed via the O/S/F wheel arch according to eLearn... You're able to access all electrical connections for testing from here too.
  • 319 - Nuova Panda 1.3 Multijet STARTER MOTOR - R.R.pdf
I've got the under tray off my 1.3MJ 4x4 at the moment (to repaint it...) Crawling under the car, i can't even see the starter motor either! Apparently it's on the back of the engine, below the EGR valve, above the 4x4 transfer unit and concealed by the clutch/gearbox at one side and the alternator at other!
These photos of this cutaway engine might help get you nearer... see https://www.team-bhp.com/forum/technical-stuff/118230-engine-pics-fiat-multijet-1-3-90-vgt.html
Here's one of those photos, showing the back of the 1.3 Multijet engine (although maybe not the precise version from the Panda) - which I've added labels to. Starter is the big red rectangle.
However, as mentioned by others, much more likely to be the earth connection between the gearbox and the body shell – this (or its contact points) corrodes and will prevent the starter from turning.
I meant to add above: the earth 'strap' is bolted to the front 'chassis rail' near the front of the battery and the other end to one of the bolts of the bell housing, under the battery tray and on top of the gearbox. All rather less difficult to get to!
Red arrow points to the 'chassis' end - battery has been removed here.
Offside for an Italian maybe.. 🤔
Basically it is bolted to the Gearbox clutch bellhousing.. (so left side of car, but almost Central for electrical connections)
So remove air cleaner and it's under the inlet manifold😉
Battery tray would improve access to bolts,
maybe not the electrics..
