jonnyboy54321
Hi all. Have done a search!
A little while ago I bought a 2014 4x4 multijet. Non-runner with a snapped chain. Trailered it back and parked up as I sourced parts. Got a s/h known good low mileage engine - complete just needed ancilliaries and my original loom. Swapped the lump into the car and she wouldnt crank. I suspected I had made a mess of the starter connections, got my pal (mechanic) to do some testing as I struggled to get my hands up there (lol). He worked out that there was no starter wiring fault - the starter was disabled. Did a work around with the relay and got it to crank but no start. We worked out theres a lift pump in the tank - it wasnt being energised. Again, a workaround via relay bridging. Still no start. (I know about the clutch pedal btw). I then recalled that I had, very tiredly, inadvertantly touched the ecu body when tightening the positive battery terminal and therefore feared the worst. When plugged with with snapon the car was showing a engine management code P0641-49 Sensor Supply 1 - internal electronic failure. Did some research, asked some in questions in Fiat circles and on FB, and the consensus was that I had foobarred the ECU. Spoke to a few ecu companies, only one said they could test it, off it went. Got a message to say testing was inconclusive - suspected faulty component but unclear which so the solution was to clone the ecu. They are a real rare one, 55257739 - I eventually found one that was known okay and took it to said repair company (the plan was actually just to swap out the ecu/cluster/locks/keys/bcm from the donor car as it was a lot cheaper, and quicker for me to sort, but they couldnt find the key so not an option). They called after a couple of hours "struggling to clone it but solution is to swap out data chip from your knackered ECU into the replacement, have we your permission?". I questioned if it would definitely work, "yes it will, just leave it 36/48 hrs before you try it. for the sealant to set". Picked it up, told by them "100% went okay, you will be fine".
Reassembled the car (incredibly carefully!!!). No crank, no lift pump prime no start. Calmed down after a while. Code P0641-49 still present, but now joined by these:-
Instrument panel U1733-87 lost comm with CTM
Body Computer B10AA-4A Check configuration failed - incorrect component installed
U1733-87 CTM node on B CAN missing a message
B12A6 -13 Daylights front parking light right open circuit
Controlled Coupling Module C2005-68 ELD from brake system fail - event information
My pal is sure sure the only present code before we pulled and sent off the ecu was the P0641-49 Engine management one. My suspicion is that there is now some sort of non-coded or immobiliser issue between the replacement ecu and the car - so I am in a worse position than I was, I do have the original ecu but the data chip is out of it so its not like I can swap it back and try it.
Clearly the "faulty ecu" is a red herring - and the original code/no start etc is something else entirely.
I am tearing my hair out at this point - need to work through but don't know what else the cause could be, electronickery isn't my thing tbh.
Anyone have any pointers? I will plug in with MES as soon as I can get it to run on wifes laptop.
John
John
