Technical Random starting problems after cambelt change
Voko
Whitchurch, Hants
Hi All,
A bit of an odd issue, I changed the cambelt using the guide and confident everything is set up ok, went for a drive everything ran beautifully. However, sometimes when I start the car it has to crank for ages (10s of seconds) before it starts, but sometimes it starts first pull. Once it does start it runs perfect idle and on the road. I’m guessing I’ve disturbed something, or having the battery disconnected a long time has done something. Could be a coincidence? Anyone have any thoughts about what could randomly effect starting but nothing else, it can happen hot or cold I can hear the fuel pump prime every time and the ‘key’ symbol goes out on the dash
All done an ECU scan etc no errors showing
Mike
Hi Mike,
Glad to hear all went well with the cam belt swap. (y) Just wanted to offer my good luck wishes!
Lacking the competence and having half-sorted cold-cold start issues on the b-95 (see link below), I'll for your sake abstain from any guessing(!). For the b-95 I'll continue disconnecting and cleaning sensor and ground connections. If the problem(s) persists I'll, thanks to @Ilkka, start investigating the Lambda sensor, MAF, and individual fuel injector function.
Good luck in the sleuthing and hoping you'll share your findings/ruling-outs for forum-hive-knowledge-bank building,
tjr
Changed the crank sensor made no difference. Cleaned every relay, fuse and connector I could find in the engine bay, no difference. I think the next stage is to double check I’ve got the timing right, still not convinced it would give these random symptoms though, unless it’s very sensitive to differences in crank and cam sensor output
  • Thanks
Reactions: tjr
Thanks for the update, sorry about the dead-end.
(The b-95 has been garaged since last fall, this evening I discovered flats on both front tires... 🙄 On a positive note it started right up(?!).)
The cam position sensor is/was alright? I damaged it, but I had both cam’s out.
