General Problems pulling off!!!
multipla-aire
Excuse the title but I am trying to find out what is causing my diesel Multipla to judder when I pull off in first gear. It's OK if I rev it quite high and really slowly let the clutch out but if I dont then it will stall which is, in my experience unusual for a torquey diesel.
Any advice would be very welcome.
Have had a look nothing seems split and the clutch seems OK sometimes a little stiff to get it into reverse, could this really be the problem?
The cars done 55000 miles it doesn't feel like clutch slip and doesn't happen any other time apart pulling away. Not sure about fuel/electrical problems though although would it not be apparent at other times? I don't believe that the clutch has ever been changed so is 55000 miles old, guess this makes for a likely candidate!!
I get clutch judder in my JTD (72k miles).
Conventional wisdom suggests:
a) contaminated (by oil) clutch friction surface
b) worn clutch friction surface (but not so worn that it slips).
Having thought about this, I have noted that it rarely happens when Mrs. Disgusted (principal pilot of the JTD) is driving.
I conclude that it's my driving style at fault. I'm trying to be a little more carefull about feeding in power gently as I let the clutch in. It seems to work.
I hate manual gearboxes. If FIAT did an auto Multi, I'd buy another - they won't so I won't.
disgusted said:
...Having thought about this, I have noted that it rarely happens when Mrs. Disgusted (principal pilot of the JTD) is driving.
Perhaps you should get Mrs Disgusted to show you how to pull off yourself
Get it looked at ASAP! Ours has been doing the same (1st gear pulling off and also on reversing slowly) for a month or so now. It is now sitting in a garage completely seized - we reckon the diff went...
:cry: :bang:
Now there's nothing to say that the juddering was definitely the cause or a symptom, but I wouldn't want to chance it...
Car is still in garage waiting for new gearbox & diff to arrive from Italy - Fiat Uk don't seem to know the meaning of customer care. (n) (Thankfully the garage do...)
So did you find out why? Mine does this occasionally if I am driving on a low tank (at keast I think that is the common denominator).
