Van Diemen
What are peoples thoughts on Panda pedal position for healing and toeing?
Can do it no problem. You have to be reasonably hard on the brakes though, but no pointy heel and toeing otherwise i guess.
So its fine, but i admit many other cars have better pedal positions. Its not so much the pedal positions its more that you sit so upright in the panda. That said if you know how to heel and toe you'll adapt to it okay.
I think the main issue is the absolutely awful feel of the brake pedal no doubt to the linkages and the brake master cylinder being on the left hand side. However, under heavy-ish braking its a bit easier.
One place I'd use HnT without heavy braking would be approaching a downhill roundabout/junction where I'd want to do a rev-matched downshift but hold the speed with the brakes so it doesn't run on....
I'll have to have another go tomorrow
Chris
Don't have a problem with the pedal positioning but I definately find the brakes too sensitive for easy healing and toeing. Need to be really delicate to avoid standing the car on its nose. I'm thinking of trying harder pads to see if this helps. Anyone else gone down this route?
On a related matter, as Chris mentions, the ECU seems to cut power as soon a you apply the brakes which also makes left foot braking a no-no.![]()
I have never really gotten the point in it though, any one care to explain?
As i said earlier it will work better when you brake harder. The ECU does not prevent you from blipping the throttle when you are on the brake.
The first video illustrates it to perfection....The 'blipping' of the throttle allows smoother rev-matched gear downshifts whilst still controlling the braking....Maintaining speed and momentum (which is key to fast lap times)
The race car in the video has such a snappy throttle that the engine responds instantly to the quick 'blip' therefore allowing the smooth downshift and maintained power....The pedal box is roomy and the pedals are evenly matched and bottom pivotted to allow it.
However, in a standard road car, the throttle response isn't anywhere near that quick, the throttle is usually bottom pivotted, whereas the brake is usually top pivotted, meaning they 'travel' in 'opposite' directions making it all the more difficult and to be honest....we're not talking a huge amount of benefit in terms of time saved, certainly not in a normal road scenario.
Personally I'd leave it for track days and more importantly, track cars....![]()
....not sure about 'most' road cars having bottom pivotted throttle pedals though....
....but while driving my favourite roads at 6am on a Sunday morning, a perfectly timed heel and toe downchange or two really adds to the experience....
