Sparks1061
Hi So finally was able to read the error codes on my 2018 ducato with Comfortmatic gear box, and I have the following message with the engine running (Can clear it when the engine is not running)
P2919-64 - thrust bearing Signal/message plausibility,
Anyone any ideas,? Am I looking at a possible sensor fault and if so can I get to the sensor to check the wiring? or is it likely to be a gearbox out and new thrust bearing?
