Finally got this problem sorted....no surprise though, it needed a new modified throttle body. The Wahler unit failed inside the electrical half, and no sign that water had got into it. I suspect these seize up and something blows on the circuitry.
The modified throttle unit's flap is much more sturdy, in a better open position (allows optimal airflow where the Wahler is slightly off fully open). As the new unit has dropped in price and is about £300 cheaper than from the dealer, it was time to try one as the only other possibility was a faulty Injection ECU.
I used a Launch Creader VIII for the diagnostics, as this shows Target Air Mass and Actual Air Mass readings - a good hint that if mis-matched then there is an airflow problem or a sensor fault. Whereas previously I could only get the Mass readings to match by removing the electrical half of the throttle body & turning the flap manually, the new throttle body (once fault has been reset) matches the target mass figure correctly.
To help others with diagnosing what the fault cause is, here's some live data of a good engine with new modified throttle body, so you can compare yours with this engine.
All figures engine idling & cold, ambient temp 21ºC
Target Air Mass: 282mg/injec.
Air Mass Measured: 291.50 mg/injec. but accurately follows target figure
Atmospheric Pressure: 1019mbar
Air Temp (Air Flow Meter): 25.56ºC
Throttle Solenoid Valve opening: 87.06%
Throttle Status: In Correct Positiom *** please not this says the same if the old faulty Wahler unit is fitted so don't rely on this reading to assist you! ***
Also the new throttle body behaves differently to the Wahler unit, it flips shut then open after ignition is turned on, and can be seen to operate as the spindle end is exposed on these. There is a strong return spring also, which will assist in keeping the valve in the open position, unlike the Wahler unit.
Happy Days
