tidewatcher
The waste gate is not seized, you can get a 16 m open end spanner onto the little lever that moves the waste gate and it is free to move though the spring pressure is quite high. It operates only on pressure there does not appear to be an electrical connection. I have now driven the van for four hundred miles using top grade diesel and the hunting and lumpy tick over is still there. A real pain in stop start traffic. No management light has come on. I started the van again today and the sequence goes like this.
Engine starts and ticks over fine for three to four minutes then the hunting begins.
If I increase revs then slowly close the throttle it ticks over smoothly but another blip will bring back the hunting.
I removed the vacuum pipe from the the solenoid to the egr valve, no change.
I felt for vacuum pressure on the egr valve inlet and it seemed reasonable.
All pipes on the egr valve and lumpy tickover, block off the vent to atmosphere little pipe/filter and the engine goes to smooth tickover over.
Reckon it’s either an air leak on the vacuum pipes though I cannot see anything untoward or more likely a partially sticking egr valve. I assume as it is vacuum driven not electrically operated the management system may not know what’s going on.
Had to use the van and also have been busy in other areas so back on the case now. Removing the egr valve look a little testing but needs must.
