Premaster equivalent of a 2014 Ducato with a 3.0 150k
The waste gate arm completely retracts during start. vacuum is 25lbs before solenoid, 15lbs at WG valve side
Does this mean that the wastegate valve is open?
When I remove electrical, valve side pressure drops to zero and arm retracts
On the test drive,, The pressure never drops below 15 lbs. at the valve except for a moment when shifting.. until I go into limp mode.
The turbo pressure is about 160 on my scanner when ecu calls for 200 {Low Boost}?
Is the Waste gate staying open if the gauge stays around 15 lbs. and the arm stays retracted causing low boost.
THANKS
THANKS
- Model
- RV
- Year
- 2014
- Mileage
- 15000
