As always I like to try and wait a little while and give you more to read
First off the megasquirt.
As i mentioned in my last post, i damaged a pin on the processor and was unable to fully test it. Well I ordered myself a big pack from china off of ebay.
As you can see from the pictures below: There is a small connector, like a component lead, that goes through the processor pcb, which then clips onto this femal to male socket rail. This is then pushed into another female to male socket that I have already soldered on to the main pcb.
However as I was about to repair the broken one, I knocked the opposite side and snapped the one paralel. Nevermind, got lots of spares now.
Plugged in my stim and it's all working
Also ordered myself a bluetooth adapter from efi analytics, so will be able to mount my phone or a cheap tablet on my windscreen and monitor all the inputs. Yes I have a stupid size screen on my phone (OnePlus One)
Time to get on with the brakes, the pipes were getting in the way.
As i was struggling with bending the brake pipes around the steering rack, I masking taped the new pipes to the old ones as a template and bent around them. Ordered a pack of male to male adapters and made the joins under the car, about level with the handbrake.
Painted the brackets and brake cylinders in hammerite, brand new master clyinder too. Mounted up and pipes routed.
Who doesn't like shiny new things, been gathering dust for the past few years. Nice to finally get them out the box. Brand new coilovers, brand new top mounts and with brand new oval locking washers (the washer that mounts on top of the strut and top mount)
To prevent rust and corrison of the struts, i dismantled them and gave them a liberal coating of ACF-50 and then lubed the threads with Corrosion Block grease.
I roughly undersealed the front half of the car, mainly as it's hard to acess the n/s of the vehicle due to me storing all the old crap and bonnet are stored that side. The box sections will be covered in ACF-50 or some clear waxoyl.
Even covered all wheel arches with underseal, after brushing off the very crusty bits around the brake pipe holders. Luckily I've got some spare brake pipe clips. The one on the far left is from paws and the others spares from the shoebox.
Mounted the struts / springs in the arches. Tightened up the top nut on the bench, in the vice. One did up fine, the second the threaded piece started spinning into the lock washer. Not happy with it, i got my spring compressors out and grabbed an old lock washer from the old struts. The strut still spun and took a chunk out of it >.<
I'm going to wait until it's back on the floor and swap it over to the last spare i've got.
I sill haven't been able to remove what's left of a bumper bolt. I had to drill the head off due to it seizing. As you can see from the damage to the surrounding area, I already tried multiple mole grips, after letting it soak in plus gas and then applying plenty of heat. Even my smallest irwin socket (3/16) just chewed up what was left of the bolt head.
I think I'm just going to cut it flush, drill it out and see if i can retap, or ill just add a bolt/lock nut instead
Next I wanted to reattach the wishbones and ARBs. New strongflex yellow bushes were used through out. I had to remove some of the material inside the rear wishbone bushes, as they werent sitting flush with the wishbone. (no pictures of this im afraid).
Also had to file some material off from the front wishbone bushes and make them a little shorter, due to them being a very tight fit. As standard length, trying to use a jack to push them in their recess, it was starting to lift the car.
Dug around for my arb brackets, though i could scavenge the last set, i'd rather have some new ones.
As you can see, this was the nearside bush and bracket, surprised it didnt just snap off. Then again the wishbone took most of the impact and snapped clean in half.
With the wishbones on, i lined up the arb. Trying to put the bolts into the floor pan, i thought i ended up stripping the threads on the off side. Winding the bolt back out i could see that it had almost started to cross thread. Checked my taps to see if i had an m10x1.25 and retap the holes to clean them up.
Well it turns out ive got a m10x1.5 and a m10x1.75 but not a 1.25m, so another ebay purchase was made for a tap and a die.
Retapped both of the captive buts on the O/S and reattatched the ARB. Retapping the captive nuts meant that there were nice clean threads for the bolts to easily locate and tighten Those strongflex bushes are 'fatter' than the OEM ones and had to get out the rubber hammer and give them a good whack to get them on, especially over the wishbone bush.
Started sorting the nearside and i started to cross thread one of the bolts. Out came the tap(s) again and another nice clean threaded captive nut was sorted
I then realised I'd tightend both bolts but forgotten to actually put the arb to wishbone bracket on
So off it all came again and i reattatched the arb, this time i also got my bottle jack out and used it to provide a more even and constant force than hitting it with a hammer.
Started winding both bolts back in, they were going in fine,the one that i'd retapped went in but was a bit stiff. The other bolt however, the one captive nut that i didnt retap. It started to get a little stiff but no different from the others..... Kept cranking the ratchet and suddenly lost all tension.
The bolt was spinning freely, i thought id snapped the threads but couldnt clearly see.
So i undid the other bolt for the wishbone bush and removed the arb bracket. Got a big screwdriver and pulled the bracket off the bush.
I tried levering between the bolt and the floor pan whilst winding the bolt out. Hoping that if it was simply a stripped thread i could force it to wind on the remaining threads.
I couldnt apply enough pressure so had another idea. If i removed the wishbone completely, i could then fit a big open ended spanner around the protruding threads and use the bottle jack on the other end of the spanner to act as a big lever.
Car jacked back up in the air, unbolted front wishbone bush and removed, then placed back down on the stands. Got myself a big adjustable spanner and hammered it between the bolt and the floor pan. Got the bottle jack under the other end of the spanner and started applying pressure. I was actually starting to lift the car off the stands and bend the spanner.
It's not exactly a small or cheap chinese spanner either.
Tried winding the bolt out, just kept spinning and spinning. It wasn't winding out. Not sure what else i could do apart from cutting the bolt head off, drilling it out and hoping i could retap.
I removed the spanner and took a closer look at the threads of the bolt, to double check and see if had started winding out slowly.
Looked at the threads and wiggled the bolt around a bit as there was plenty of movement.
Turns out I havent just cross threaded the bolt.... i'd snapped the welds for the captive nut.....
(ignore the poor undersealing in these pictures, i was leaning in from under the off side and didnt want to keep getting covered in underseal. Im going to redo this side once i've moved all the crap from the passenger side of the car.)
The captive nut is in box section of the floor, no easy way to access it from below or to the side. Not without cutting out big chunk out the box section, sliding it a diy piece of box section with a captive nut already welded on and reweld and paint.
Okay so what if i cut the bolt and drilled out what's left? Well i'd still have nothing to put a bolt in to and I'd then have an old broken captive nut rattling round. If i drilled out the small hole between the two captive nuts and removed what's left of the captive nut, i'd still have no way of rewelding a new captive nut in there. Plus the box section is just that, a box with sides. I dont want to weaken it and apparently these are like welding paper.
So i've thought of a soloution but im afraid i cant carry it out yet.
I'm going to figure out where the bolt is in relation to the passenger footwell; I'll probably drill a small pilot hole with a long drill from underneath. Then drill a larger hole through the floor, probably a little bit bigger than a 19mm socket.
This will then allow me to fit a big washer and a lock nut through the passenger floor and tighten the bolt, i'll hide the evidence with a grommet and cover it back up with the carpet. No one will ever know.
Just means that if i ever have to unbolt the wishbone it'll be a two man job. One person inside the car to apply tension to the nut whilst the other undoes the bolt underneath.
I wont be able to sort it for a little while yet though, i cant get to the passenger footwell to drill through it. The interior is a bit of a mess
Started getting on with the wiring.
ABS - gone
Code system - gone
Airbag wiring & ecu- gone
All traces of the wiring have been removed. Well except the the rear abs sensors, the car is full of stuff and cant get in the back.
I still need to remove the OBD socket and various wiring but that should be the majority of the wiring im removing inside the cabin. Got confused on the wiring diagrams, forgetting the diagrams of components is for LHD vehicles. So i was looking for R10 (the OBD socket) in the passenger footwell for a few minutes. Then realised R10 meant the OBD.....
The wiring diagram for the diagnostic system isnt actually listed in the contents of the wiring section in the tech manual. It's the last few pages of the 'electronic systems' in volume 4.
Also decided to take my old airbag ecu apart and have a look at how it works. Wanted to see how it senses a crash as there are no crash sensors in the body work. The small white box you can see probably has a 'ball and tube' type arragement. So if enough force is applied, the ball shoots forward (hence the arrow making sure you mount it the correct way) and hits a switch.
I've been tempted to mount the Megasquirt where the airbag ecu was but i've got other plans. I mainly wanted take the airbag ecu apart to see how much space there was inside the housing and if i could modify it to fit something else in there.
The wire strip down begins. Mainly peeling / cutting off old electrical tape. You can also see i'd already got the helping hands and heat shrink out. I accidently snipped through one of the wires when removing the tape. It was for the o/s indicator, so thought id best solder it back together
As you can see i printed out the wiring diagrams and put them in a folder, saves me having to keep taking my netbook in the garage or constanly having to look at my phone. Plus i can easily scribble on paper and make any notes if i need to.
D4 connector on an MPI Seicento. Only five wires on these.
Pin 7 - Grey / Yellow
Oil pressure switch to the warning light on the dash - this is going to be removed. Got an oil pressure gauge which will be a better warning sign, if the light comes on it's probably too late.
Pin 8 - black / purple
Straight through the D4, to a ring terminal on to the alternator D+. This provides the 'recharging' warning light when you first turn the ignition and also sends a D+ signal to the power steering ecu pin 12.
Pin 9 - Orange / white
power to charcoal canister solenoid
Pin 10 - Pink
Output from main relay. Provides power for fuel pump, injectors, coil and a 15A fuse by the ECU. The fuse (B40) then sends power to lambda sensors and the power to the charcoal canister.
Pin 20 - red.
This just goes straight through the D4 to a ring termial and bolts to the starter. It's the ignition switch power to the starter.
Pulled apart the ecu connector to make it easier to start cutting and labelling wires.
Then labelled up all the wires that I've got left and left them hanging in the bay. Hopefully all my labels make sense to me and dont fall off.
Various things like; signal to tacho, cooling fan signal etc.
The excess of wires that you can see in the foreground is just for the external lighting, so much excess.
I really want to remove the large grommet that the wiring passes through but struggling to split it, think im going to have to cut it with a hacksaw at this rate. I want to be able to access all wires and start cutting out the lighting wiring, route it through the cabin and then through the arches instead. Makes for a much neater install i think.
Current job list:
Completely remove all the OBD wiring (though i dont know whether to keep it for power steering codes, doubt it ever would throw a code though
Cut that grommet off!
Deicde where im going to drill the holes in the arches.
Route all the external lighting back through the car. This should clean up most of the spaghetti in the engine bay.
Figure out where and how im going to mount the Megasquirt. Ideally I'd like it removeable but want something stronger that a strip of velcro or something similar on the base. Maybe make up and then mount it to a base plate, weld this to the floor and then have wing nuts / thumbscrews holding it down. Or just weld some studs / bolts to the bulkhead.
Start feeding the wires for the MS from the cabin to the bay.
Clean and paint the gearbox and gear linkage brackets.
Then do i wire up the megasquirt with the engine in or start wiring up sensors then put the engine in and trim back the excess wire? What do you guys think?
